Sexystovers 93 TSI DD and weekend racer
sexystover
202
Nov 6, 2008
allentown, New Jersey
hey all figured id make a journal.
i picked up the car from a member on here, it was previously running an FP green with DSM link, i got it without the turbo setup, ecu or fuel pump. i bolted on an evo 3 16g put in a wally 255 and got a stock 1g ECU for now. the car alreay had a bunch of mods and thne i added some things such as the SAFC 2 and downpipe.
heres the full mod list as of now
Engine- head studs, BC 272 cams, rest is stock
Turbo/Intake- EVO3 16g unported, big FMIC 2.5 inch piping, GM maf with MAFT
Exhaust- 2g mani and o2 housing unported, apexi N1 downpipe/cat delete , to 2.5" piping with dynomax straight through muffler
Trans/Clutch- ACT 2600 rest is stock
Fuel- Walboro 255 rewired, AFPR, 93 pump gas
Tuning- SAFC 2
so far the car has run a best of 13.4 at 102mph on 8psi creeping up to 15psi at redline
i installed a hallman MBC yesterday and now have it tuned on 18psi with a 20psi spike so i cant wait to see what she will run.
You got a good journal here! I like your build so far. What are your goals?
my goals as of now are to get into the 12s and still have a reliable daily driver, i want to make the most out of the 16g setup for the winter and then come spring i plan to upgrade to a holset
HOLY CRAP! I was gonna buy that car. I was the guy that came the day before you to look at the car. I only wanted the shell though, so when you offered $1000 for the whole thing, I just said screw it. The shell is so clean, but I didn't want a 7-bolt motor, 3-bolt rear, and a junk tranny. Good luck on your build.
the car is a 7/4 combo with an lsd rear not a 7/3, and the body is mint other than the driver door being replaced, it was hit at some point so the driver door was red and painted white so under the window trim you can see red paint, and the trannies perfect, just was some loose bolts
yea he told me same thing, but once i got it in the air and found the loose tranny and saw the 4bolt rear i was so excited
