setup question
95redtransam
Feb 10, 2004
texas city, Texas
Ok Im about to order a big t-28 for my 95 fwd. I currently have a 3 inch turboback, injen intake, boost control, 1st gen bov, boost guage, a/f.
My question is, do I need injectors with this setup, or will it be ok for a while? I plan on getting an intercooler first, then injectors. Unless others think differently. Thanks
As long as you don't run more than 15ish psi for the time being you will be fine on the stock injectors. With a FMIC and injectors you should be able to run 20psi no problem.
