NightRider97
- 185
- 0
- Jun 29, 2006
SW,
Nebraska
Hey guys, this is really a follow up on my previous post about my ignition problems after installing my COP setup and a new Dynatek ARC-2 ignition module.
Well I replaced my spark plugs with some new ones similar to what I'd had in there, but the store only had V-Power BKR6E-11's instead of my normal NGK BPR6E's. I was assured that there is no difference with the plugs minus the V cut electrode (which is a total gimmick, I know) and that these take the smaller socket. So if anyone knows of any problems with these please let me know.
Anyway I put those new plugs in and it seemed to run great, except I could hear a minor miss after a long drive (say 20 minutes or more), I could hear a quick "cut" here and there from the exhaust tone.
Here comes the real kicker. So I drive it a few times without any issues, and it seems the ARC-2 added a ton of bottom end torque, but having any more issues with it it seemed I was good to go.
Well I let my mom drive the car yesterday and she called me up saying the CEL was on and that the car was kinda bucking as she was driving along. So I decided that I'd go and look at the car wherever she was. I get there and check the CEL with me logger and it read "Cylinder 2 Misfire Detected". Which is the same cylinder that threw a code the last time I had a cylinder misfire, but that was when I was running the COP setup straight from the igniter.
I don't understand why its always the same cylinder, but anyway that's not the point of the story.
So I decided I'd drive the car home, and so I started on my way out of town (lots of stop lights on the way out of town) and I noticed right away that the car had absolutely NO POWER. I mean I killed it pulling out onto a street and almost got hit, started it back up and had to rev the engine up to 2700rpm to even get it to take off. I had to do this at every stop light on my way out of town. UNTIL, I stopped at one stop light and when I barely started to push on the gas it backfired two pops out the exhaust. Completely scared the crap out of me, and my mom was like, THERE IT GOES AGAIN, THAT'S HOW IT WAS RUNNING FOR ME! I was like, WTF what do you mean that's how it was running for you!
At this point I was already on my way out of the parking lot and into the street and so I tried to take off down the street and it just started popping, and popping and popping. So I tried accelerating and it just popped and popped, I got it up to 2200rpm and then it just like hit a brick wall and it just refused to go any higher. It started blowing a rich cloud of black smoke out the exhaust and just popped louder and louder.
I pull over and shut the car off, fearing the worst, timing belt had skipped a cog or something. I check it out and the belt is tight. So I do the only other thing I could really easily do, I unplug the ARC-2 box and plug the COP setup straight back into the factory harness. Fire the car back up and it ran just fine! WTF?
Dynatek wants me to send my box back to have it tested. I just want to run this by you guys first to find out if it may be an issue with my car. But it doesn't look good for the ARC-2, since it cured the problem when I unplugged it.
