sensor readings
EpicPopcicle
46
Feb 9, 2011
columbus, Ohio
Anyone know where i can find all the sensor readings i just got a scanner and hooked it up and all my sensors are giving out readings but not too sure what they should all be reading at. Is there a write up somewhere?
The manual maybe never saw something with all sensors,just specific ones are they not working. If there not giving you issues i would just drive it unitl you get cel lights?
I would only problem is, is that i have a check engine light due to the test pipe not having an o2 sensor so i always throw a CEL. But everything seems to be just fine as of right now
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
