1G sensor grounds together? sensor 12v together?
compression
1,433
12
Dec 9, 2004
vero beach, Florida
Specifically CAS 12v and injector resistor 12v , and TPS ground with coolant temp sensor ground?
Can I tie them together? I've added 1 large plug to separate the wire-harness for my relocation and I want to condense wires.
The TPS and numerous other sensors on the car are only 5v. You need to keep your 5v sensor grounds separate from the 12v sensor grounds... .
Correct, bit i believe those are both 5v , I was referring to the pin on the ecu , "sensors ground" I assume since they both need to go there it would be ok to connect them, I just wanted to Make sure the ground wasnt like a trigger or something on one of them.
