Sd q?
JuGs
674
Jul 20, 2008
Marshall, Wisconsin
Ok i read alotabout going sd. Now my question is of o were to go sd can i just T off my brake booster line for the moment? I see a common spot is right next to the brake booster port on the intake mani but why not just T off it?
Im still undesided for sd or ot butjust cerious
Sure. That where I mounted my MAP and have had no problems. I've been running this way for years. I pulled the booster hose from the nipple on the manifold then unscrewed the nipple, got a brass fitting that matched the thread on the nipple on one end and barbed on the other and had a thread hole in the side for the MAP sensor and just screwed all together. Was really easy, simple, & cheap. Also, if I want to go back to stock just undo everything and put it back like it was.
Ok I thought I could because I didthe 6 boltswap and I have the stock map sensor T'ed off the brake booster but wasnt sure if itd effect the SD if i went that route. Thanks for the responces I jut like more opinion before I make a desision
