SD log, let me know what you think
zanderson
161
Nov 21, 2010
Brookings, South Dakota
Just got the SD set up and want some more advice from what I've gotten on the link forums, as well as here. It's not fully set up, the MAP sensor is plumbed off the PCV manifold fitting and isn't securely mounted yet (tapping the manifold for a dedicated source soon).
Mods- ebay 16g, 3" straight back exhaust, Aeromotive AFPR with base fuel set at 43-44psi, wally 255hp, SD package through ecmlink, ebay intake pipe and cone filter. I don't have a lower timing cover currently, so base timing isn't set dead on yet that I know of. IAC is currently unhooked because it idle surges worse with it plugged in (2 bad coils).
Let me know what you think, the first log is before I ran the Link SD tool, 2nd log is after I ran it. Advice, changes, etc?
