SD install mitsu bundle
Your picture isn't working but the SD cable should have 3 plugs. The big wide one plugs into your stock MAS connector , the 3 pin one plugs into the MAP sensor and the 2 pin one plugs into the IAT sensor.
Putting the picture as attachment. Either I couldn't get the mitsu style 4bar sensor into this or its the wrong one.
Since you bought a Mitsu-Style MAP sensor then you don't use that 3-pin GM connector. I ordered the same cable a couple of months ago and was confused as well. You use the factory harness for the MDP sensor which is where the new Mitsu-Style sensor would be placed anyway. Then in ECMLINK you adjust the settings so it knows the Mitsu-Style map replaced the old MDP sensor on the intake manifold. Mine works fine like this
