sd install wires wires
toppertopper
444
May 14, 2009
edmonton, AB, Canada
maybe i am reading to much, going in circles.. have egr delete and just uninstalled gm 3" maf and translator
doing a gm iat , 4 bar map install
Iat tap in at maf connector
green and orange stipe (pin 8) ,.Green and black stripe pin 6
4 bar map is where i am going round and round
port a 4 bar map (ground) ---Maf pin 6 again ?
port b (0-5v) ----Pin 7mas plug
port c (+5v power) pin 4 mas plug
or
4 bar map
tap red wire map --- pin 1 tps
cut green/black stripe wire from egr - black wire 4 bar map
cut blue/yellow stripe wire - blue wire map 4 bar map
If i can use one or the other , do i just change inputs in dsmlink
One other quick question i have wb installed pin 4 i just sim nb in dsm link ..Can or do i just cut pin 4 or just spice into it (i have it spliced in atm)
