scm6152e and gt35r wheel info
stace
86
16
May 27, 2008
Belleville, ON, Canada
I was given a scm6152e with a badly damaged turbine wheel. thats all that is wrong with it.
I found a new t350 stage 5 shaft for it.
Can i use a standard t3/t4 360thrust bearings and journal bearings from this kit?
http://www.ebay.ca/itm/270897293702?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2961wt_907
and
If i were to buy a new gt35r compressor wheel for it .. would i need to get it balanced? Since the shaft and the wheels should come individually balanced.
Seems a gt35r wheel is cheaper then sending it away to get balanced.
  • Wanted 6 bolt NT water pipe
    • chrisman287
