Schwitzer T04B 61 trim turbo
bOOstd GSX
931
Nov 29, 2003
Plum, Pennsylvania
I just got a brand new Schwitzer T04B 61 trim turbo and a cast manifold and I have a few questions:
1) Will my car run properly with just the safc or am I going to have to dsmlink v2 or some other engine management in order for it to operate properly?
2) What wastegate shoudl I go with and what spring pressure?
I am used to having internally gated turbos and don't know much abotu this new world of externally gated beasts.
SOMEONE PLEASE HELP! :p
You list no other mods, and if your asking if just a s-afc will work im assuming you have no injectors or fuel pump. In which case, your not ready for a turbo upgrade IMO.
I guess that was kind of a stupid post assuming you knew my mods...
Here are my other mods:
Here is my engine setup:
Slowboy Stage II race head which consists of:
• Ported and polished
• Clevite rod bearings
• Clevite main bearings
• ARP rod bolts
Slowboy Stage III race block which consists of:
• Eagle rods
• Ross pistons
• Hot tanked
• Pressure checked
• Competition valve job
• Stage III port work
• New valve stem seals
• SS swirl polished, and undercut valves
• New guides
• Stock springs and retainers
• Decked head surface
• New exhaust manifold studs
• 660's
• Walbro 255lph
• Aeromotive AFPR
• Apex'i 3" exhaust (no cat)
• Apex'i 3" downpipe
• GReddy 24row FMIC
• Upper IC piping
• GReddy Type S BOV
• 1G 60mm Throttle body
• Apex'i S-AFC version II
• GReddy profec b spec-II
• HKS Turbo Timer
• Pocketlogger
• K&N filter
• Injen intake pipe
• Pocketlogger
• NGK plugs
• Magnecor wires
My tranny conisits of:
• Full rebuild
• End clutches
• Translab shift kit
• IPT high stall torque convertor
Also using a 50 shot of nitrous to spool the turbo a little bit quicker.
NOTE: I am running 95 octane pump gas.
About how much bigger do you think? I was thinking 880's or would 770's work?
im not sure id wanna spray a 50shot on top of high boost on pump gas, but. Your obviously already controlling your injectors with the s-afc so... Personally if your funds can afford it, get dsmlink no doubt.
If you're willing to get DSMlink then get 880s. You can in theory control 720s with an S-AFC, but your timing will be very high so I don't reccomend it. Some people also have trouble getting a good idle. And like Anconover said I wouldn't spray unless you are running race gas or lower boost. Start at like 15 psi and work your way up.
