Bullseye t3/t04b V trim DYNO results!
About 7 lbs/min, the 60-1 will move a lot more air at lower boost. The 60 trim has 6 "curved" inducer blades, the 60-1 has 7 "straight" inducer blades.
Good to hear! I just ordered a 60-1 from AGP, the RS60T with the best turbine housing, the Bullseye. Same housing as on my RS49. Can't say enough about the tubine and having the 60-1 flow more air at a lower boost makes it even better! Mark
Theres is no way water/meth is better than straight methanol. Try running 28+ psi on water/meth mix compared to straight methanol.
im not saying its beter, im saying its better/cheaper for me
im not looking for all out power, just a good system that will allow me to safely boost higher with no knock in hotter weather without worry
All I have to say is ............................. Holy Shiot, I have not seen a post venture this far off course in quite some time.
Nazthug.. I would assume you are nazar on dsmlink? I am donnienall626.
nice numbers.. lets see what it will do with the race gas.
and I got to looked at my timing the other day and the exhaust can is retarded one tooth. so MAYBE that is why I am flowing about 5lbs/min more airflow than you. I think you were flowing 38 lbs/min on that run and I am flowing 42.5 lbs/min from 6k-7,300 rpms. Hmm I wonder...
anywho, yes bullseye power stands behind their products VERY MUCH. it has been discussed in several 20+ page long threads on this site alone. lets leave it at that, who cares who sells his product or how they cloned his site.
