SCCA Wiregrass Region Solo II Event #1
4G63FLA
156
Jan 4, 2007
................, Alaska
Wiregrass Region SCCA Solo II Event #1
8:00 am, I awoke from my Quality Inn hotel bed to a beautiful sunny day in Dothan Alabama. I couldn't help but have a smile on my face for this was the first race I had run in over 3 years now. I stepped outside to see how the weather was, and it couldn't be more perfect. It was bright, sunny, not a cloud in the sky and it was about 35 degrees. Perfect turbo weather I thought to myself. Jumped in the shower and gathered my things and headed out to the track. Which was about 20 minutes from the hotel we were staying at. I pull into the event site and there were only a few cars there and the SCCA officials laying the day's course. I went to the registration table, signed in, got my armband and headed over to the pit area to set up shop. My girlfriend and official photographer of the #32 FP car would arrive later in the day.
10:30 am – Driver's meeting. We all gathered around the SCCA officials to go over the track layout a bit and what the standing rules of the day would be. After a brief (thank god) driver's meeting, we were each handed a copy of the track layout and had the opportunity to walk the track. As I walked the track with an SCCA-Pro driver from the Kobi Subaru dealership, I noticed the track was a bit confusing in some sections. We called the SCCA officials over to get them to setup some more pointer cones here and there thinking it could be easy to get lost in some sections, more on that later. After walking the track 3 times, it was time to get the racing underway.
1:30 pm – My first runs. As I pull into the Tech area, and I am greeted by Jay Scott, one of the SCCA officials my girlfriend and I had dinner with the night before. We chatted for a minute or two until the timing official called me to the line. The track was a very big Auto Cross track and they were running 2 to 3 cars at a time. The timing official turned to me and said, "ready"....GO !!!!! I revved the Tsi to 2500 RPMs and I was off on my 1st run of the day. Right up a short shoot and into a 75 degree left hander and I was shifting into 2nd gear. 15 pounds of boost and the turbo was screaming. Took a long right-handed sweeper followed by a hard 90 degree left-hander. Hard on the brakes for a brief second and then back on the gas shifting into second gear as I come to the 1st cross over box on the course. Slight right-hander as I reach the longest straight away on the track. Hard on the gas and into 3rd gear for the first time. Reaching the end of the straight, I stab the brakes pretty hard and slide slightly as I go around a 180 into the slalom section. Having walked the course earlier in the day, I knew I needed to enter this section from the right, so I could come out on the right side at the end to set up for the next left-handed sweeper. Through the slalom, I found a steady pressure for the gas and I worked the wheel bake and forth through the cones. Coming out on the right side, I setup for the left-handed sweeper followed by a VERY hard left had turn heading back into the crossover box. Shoot to the right through a section of 3 offset gates heading towards the back of the course. Around a 180 right-hander and through to the high-speed slalom section. Left, back to the right, left and into an extremely hard braking right-hander heading towards the start/finish line. I went in a little too hot and over shot this turn and around I went. A full 360 with an extra 180 so the rear of the car was point in the right direction at least. A quick turn around I was off to the start/finish line. I drive the car back over to the tech area and head over to the timing area to check my time. Not a very good run at all--84.377 seconds. I noticed the time-keeper had me down for hitting a cone that I some how didn't remember hitting, and a DNF. I asked what had I done wrong and he informed me that I missed a gate coming out of the slalom section of the track. With my spinout, a cone and the missed gate, it was a pretty eventful first run. On 2nd and 3rd runs of the morning, I encountered a problem that I was not prepared for. As I went into the hard braking corners, coming out of them, the car what start to buck violently and cut off and on. After the 2nd run, I looked down at the fuel gauge to see I was at a ¼ tank. I had read on DSM Tuners that people had experienced similar problems with this before. Not a very good run either, although I did manage to trim 2 seconds off the 1st time to a 82.923 second run. Still, I didn't like the fact my car was jerking around and cutting off like that. The 3rd run went much of the same because captain unprepared here did not bring any extra fuel to the track, thinking I would not need any. Even with a cone hit I managed to run a 78.574 second run on the last pass of the first session. Shaving 4 seconds from my 2nd run.
2:45 – Lunch. As some of the carts ran the course, we had an opportunity to break for lunch. I ran up the road to local Texaco/SubWay/Meeting Place/Gas Station (we are in the sticks here) and filled the car up. I was going to make absolute sure that the jerking and cutting off was the fuel level issue and nothing more serious.
3:30 – Second session of runs. After filling up the #32 TSi I was hoping that would solve the cutoff problem. Ok, on the line and off. I get to the sections of the course where the car was shutting off and jerking badly and with a full tank of fuel, nothing doing. The car ran through the section like I would hope it would. I was so excited it did, I let out a little HELL YEAH when nothing happened. I went on through the course with more confidence then the previous 3 runs and it showed on the times. I stayed right around the 78 second mark with a 78.998. On the 5th run of the day, the official photographer/girlfriend wanted to have some fun as well. So I got her a helmet from the SCCA officials and she was going to ride with me on the next run. She must have been a good luck charm because we ran a 76.702 5th run which to that point was my personal best run of the day. She got out of the car with a huge smile on her face and wanted to go again. But she understood I wanted the last run of the day to just be me and really give it all I had. She is SO great and understanding with my racing. She is the BEST. On my last run of the day, I really got off the line in a hurry and got into 2nd gear as fast as I had all day. I seemed to hit every point on the track I wanted to and with some limited tire spin in a few sections, I finally got off my fastest run of the day as well as the fastest time of the day for the FP class as well---75.440 seconds. I felt really good about my last run with the cars performance. I thought to myself on the drive home (2 hours and 15 minutes) that if I had another 2 runs, I could have closed in on that 70 second run I had wanted to get to. Overall I was VERY, VERY pleased with the day's events and the cars performance. This was the first time I had been behind the wheel in a race in over 3 years. One of the new mods I added to the car was a DG Industries Chassis Strengthening bar, which really seemed to help keep the light rear-end of the car stable through the slalom sections. Finishing 1st overall in the FP class also was a great feeling. It's always nice in a point series to have the early lead. I don't mind being the hunted.
Finally, as I pull the TSi into the garage in Pensacola Florida, a 175 mile trip from track to home, I am exhausted from being in the sun all day and the driving time back home. I pull the car in, lock up the garage and turn the alarm system on. A good overall weekend and a GREAT time racing. I cant wait till next month with a few more mods, some more weight loss and hopefully another 1st overall position for the day. Happy boosting !!
~Eddie Garrison
:talon:
Here are a few pics from the event.
those pics came up as red x's for me Eddie.
congratulations on your great success this past weekend. we hope for the same thise weekend at CMP.
Thank you very much. I hope you guys run well and maybe get the 1-2 finish you know? Not sure whay they would have come red Xs, but I will look into it. Anyone else just see red X's? Thanks.
~Eddie
Congrats on your win and thanks for the great writeup.
Thanks Jordan. I will be posting more writeups from all the events this season. The SCCA ones are once amonth, the 2nd Sunday of every month. So there is 10 more to go there and I am going to 4 road course track events coming up later in there year begining in April at Talledaga Motor Park.
~Eddie
I was amused to read how the course was hard to walk. Cole is a well-known character on SCCAForums and it doesn't surprise me that he uses non-standard cone-placements.
What is it about your car that bumps you to F/Prepared?
- Jtoby
- Jtoby
The track in the begining was a little hard to walk. There were not enough pointer cones in the middle section of the track and even walking it people were getting lost.
Bumping into the F/Prepared class is all the weight reduction I have done. Basically, the car is gutted from the firewall back except for the carpet in the front and the 2 front seats. (Posting pics later today). Everything else is gone. Also, I believe some of the internal mods put me there as well.
Congrats on the win :thumb:
Great write-up, it makes me even more eager to get back out there.
Thanks allot man. It was GREAT to get back out there after almost 3 years of no racing at all. Cant wait to get back out there and do some more.
~Eddie
jtmcinder - I see you are running 245/45/16 Hoosiers. They fit under our 2Gs no problem? Or did you have to do any modifications to the car? Also, what wheels are you running them on? Thanks :)
~Eddie
245/45/16 is the old standard for 2Gs. For Victoracers, you want an offset around +37; for Hoosiers or V710s, you need to drop it down to about +34 or +32. My wheels are the other old standard: 16x8.5 Kosei K1s in +37. I now add a 3mm spacer for the Hoosiers.
The new standard is 285/30/18 on a 18x10 or 18x10.5 +12 or so.
If you space out your rear upper control arms to reduce camber, neither of these set-ups will tuck in. But who cares, since most of us are on pretty stiff rear springs.
But, for you, in F/Prepared, you should be looking at 23.5 x 11.5-16, 25.0 x 12.0-16, or 25.0 x 13.0-16 slicks. The first is very short for great gearing (but you'll have to go to third sometimes); the latter two are 25", but have more tread. The first two of these are available in R35 and R45A; the last is only available in R45A or R55. Personally, since I don't have a ton of power, I'd like some 23.5 x 11.5-16 R35s on 16x12s with an offset around zero. YMMV.
- Jtoby
These will all fit under the 2G no problem without any modifications correct? I am not going to flare the fenders till the end of the season, so I want a tire I can fit on some 16" wheels I have now. I need to make sure on the size of them, as they are pretty narrow. I may just end up buying some wheels for racing and not so much for looks you know? Or just switch my 18" wheels I have on there now with street treads to make those my racing wheels and put slicks on there. I got ALLOT of wheel spin with street treads on there this past weekend. Could have something to do with I need to smooth out my accelerator pressure as well. But I still want to be able to possibly use the old 16" wheels I have sitting from a previous ride. Thanks for input. :thumb: :thumb:
~Eddie
Depends on what you mean by "fit under." With the car just sitting there, you won't have any rubbing. If you try to autocross with any of these set-ups on stock springs (or Prokits or any other low-rate spring), your rear tires will be grinding into the arch of the fender big time. You have to at least roll the fender lip. Even then, you'd be forced to omit or shrink the upper-arm spacers in the rear to run 245s.
Do not "waste" money on good tires to fit skinny wheels unless the rules force you to run skinny wheels. You're in F/Prepared, so you can run almost any wheel you wish. Buy new wheels. Do it once; do it right. At least, that's my advice.
- Jtoby
- Jtoby
Right. I understand what you are saying there. Thank you very much for the input. Driving is one thing. When it comes to some of the tire issues and internals of an engine. I am not that great right now. I am trying to learn though. I appreciate all the help you and others on here post for me to read. Thanks again. As far as spring rates. I am currently getting all the parts to build my coilovers now. I will be running Tanabes 3.1 rate in the rear to start off with. And 5.8 in the front. These are SUSTEC GF210 springs. I was talking to a guy that races in the Speed World Touring Car Races and hw said these would work very well for my car. Although, he was a Tanabe sponsored driver.
p.s. - I was at the Outback Bowl this year and you guys kicked our butts. I graduated from Tennessee in 2002. GO VOLS !!!!
~Eddie
Ugh. 5.8/3.1 is only 330/176, which is close to ProKits. Nowhere near enough for autocrossing. You want to be up in the 650/375 range. Seriously. If you don't get the total roll resistance up, you'll never keep the outside front tire happy and the car won't turn.
- Jtoby
Ok I see what you are saying there. Will not get those then. Will go with something ALLOT stiffer. Thanks again.
~Eddie
This was a big factor in me going to F/Prepared. The back is basically gutted from the front seats back. Next comes the front of the car. The radio and all the centre console will be coming out this week to make some room for the guage/master switch panel that I have been working on. Will go in the place of the factory double-Din radio system. Also, all the carpet, door panels and any other misc door and trim peices that I dont really need anymore.
From what I can see, you are two hours of work and less than 15# from being legal for SM. The only serious problem is the bar connecting the C-pillars. That's not legal in SM, but, on the bright side, it is probably doing little if anything that is useful at your current level of lateral grip.
- Jtoby
ps. that upper rear STB that you have is worthless; those bent end-plates don't allow it to provide any bracing at all; I used to have one just like it (Pilot Motorsports), but have long since tossed it in the trash
Can't tell from the pics- you still have all the sound deadening in there? Did you just pull out the plastic panels, the rear seats, the rear speakers, and the rear seat belts, or did you remove anything else?
The plastic paneling is the LAST thing I'd remove in the weight reduction process- it weighs so little and makes such a big difference in how the interior of the car looks. If it's just a race car it doesn't matter but if you've gone up to such a high class because of pulling the rear panels, you should yank absolutely everything else out of the back too (within whatever rules there are even in f prepared).
If that weight reduction and the cross bar are all that's keeping you from running SM, I'd be inclined to go back to SM legal trim until you're ready to take it far past the limits of SM. Then again, you did just win in FP, so unless you want to go national what you're doing seems to be working for you.
Thanks Chris. Absolutley. Here is the link to the results. http://sccaforums.com/forums/permalink/232553/232549/ShowThread.aspx#232549 I actually missed the 1st event of the year, so I do not have an updated list of the overall standings as of yet. When I do, I will post them on here. The Wiregrass Region of the SCCA holds its Solo II events the second Sunday of every month all year long. On average, there are anywhere from 35 - 45 cars participating in the event. Cars ranging from Honda S2000s, to Miatas, to DSMs (shameless plug) all the way to full blown race cars in the area. The regions website is currently undergoing construction. But when it is finished, I will be posting the link on these boards for people to view. Thanks again.
~Eddie
  • Wanted 6 bolt NT water pipe
    • chrisman287
