2G Safe boost with 650cc fuel injectors?
wicked99gst
Sep 13, 2007
Siloam, North Carolina
Ok i run a EVO III 16g turbo with 650 cc injectors just wanna see what psi i should be running...
If your profile is correct, you need a logger and a wideband before you start boosting higher than about 15psi on pump gas. You could probably get away with more, but without a way to keep tabs on your motor, you ought to keep it low.
yea i ran my 16g with 550's at 87% duty cycle which put me around 18psi. your safe to there until you have a tune or a way of watching whats going on. i had an safcII but that was back in the days when it was only a cool little gadget to me. once i learned to use it everything fell in place and i maxed the 16g out (22psi is all ide go with it)
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
