650cc injectors
WalkedTalon
77
Jul 4, 2004
Valdosta, Georgia
Ok im not a dsm expert but i know enough that you cant just through em in and ride. What are all the supporting mods.
Well the only thing you need is a AFC or other means of adjusting the cars air/fuel ratio. Although it would be pointless to install them until you are increasing the boost dramatically.
Well im runnig 13 1/2 psi right now i got a mbc and gauge, cant achieve a higher level till i replace my bov, plan on putting in a 255lph and 650cc's at the same time hoping to boost aroung 18psi
I'm no expert either, but from what I understand, you can probably save the $$ you were going to spend on the 650s and spend it elsewhere. If you follow others' staged upgrades, there is plenty more to do before the injectors:
http://www.buschurracing.com/stage_1.html
It seems it will be a while until you need to do those injectors.
For what it is worth.
I will have to agree. Follow that path. So many want to come in and get this part or that part first and end up selling it later or going the way of the upgrade path eventually. If you do it right the first time then there is no second time.
Michael
:talon: :laser:
thanks for the advice so what is the 14b good for??? i also have one sitting in the shop, would 18lb be posible on a 14b? thanks
