SAFC2 No Display HELP!
turbospyder19
76
Dec 11, 2003
Hoffman Estates, Illinois
I just got my SAFC2 hooked up per ProstreetOnline's Howto Guide. When I turned the key to "ON" the green lights came on around the button but the LCD Display is blank. Can someone please help? Thanks!
Justin
i know this might be stupid but check your wires!!!
if the wires are hooked in the right place check the connection of the wires..
when you had to do your grounds, make sure for the ground wire when you tapped in the brown and black wires... make sure the brown one is on the ecu side... same for the pink and orange wires (for airflow, make sure pink is on the ecu side)
and when you tapped in your power wire on the 26 pin harness, make sure u used the bottom red wire, IIRC, there is a red one above it that can confuse you if u dont double check
hope that helps
Thanks for your reply, but I fixed it. The tap for the black ground didn't grab the black AFC wire, just insulation. Phew! At least the unit is good!
Remember to unclip your SAFC harness when you change your battery per Apexi. It can send a voltage spike somehow and take out your SAFC. It is rare, but can happen. It happened to me. Thats straight off an email from Apexi.
