safc2 knock
cramec2
56
Sep 7, 2004
Manchester, Connecticut
I have a 2g with 16g turbo and safc2.I have knock montior on and it reads 0 in the am and as the outside temps warm up the knock # increases..Is it true that on a 2g there is no good way to measure knock with safc2? Is it just a Bull Shi@ MONITOR for knock?
Well, it makes sense that as the outside temps warm up, your intake air temp will increase, thus increasing knock, so it sounds like the knock monitor is decently accurate. Do you know how the SAFC measures knock? Because, if it just plugs into the ECU and shows you that reading, its just as accurate as any pocketlogger.
  • Wanted 6 bolt NT water pipe
    • chrisman287
