safc2 2g knock question
bob123131
457
Dec 20, 2004
winona, Minnesota
So i know the safc 2 knock sensor does not read right on the 2g's, but i have had hooked up this way for about 6 months anywase becasue i didnt know it when i installed it. Just curious if i should be worried that it reads between 40 and 55 counts at idle and 70 at wot. I know it doesnt work but is it just off by a little and i really am having knock or do they not work at all and i probably having nothing to worry about. I do have a bit off lifter tick so it could be phantom knock. I know you are going to say get a logger and i am going to but money is tight. Basically should i continue to drive my car and not worry till i get a logger, garage it, or continue to drive and disconnect knock wire from safc 2. It wil most likely be 4 months before i can get a logger.
  • Wanted 6 bolt NT water pipe
    • chrisman287
