safc2 knk reading
ralliartist
Oct 14, 2005
Plattsmouth, Nebraska
I've done about as much research as my brain can handle and I just can't find a definite answer. I just installed my apexi safc2 and I'm still kind of new to tuning, but what the hell is the knk readings? I'm getting 40's and 50's with an occasional 60's reading. I installed my safc2 correctly and it works great and I DID NOT do the blue wire mod. so what the heck is the knk reading? it's puzzling the hell out of me.
thanks for any quick responses.
I believe thats the knock reading. You are also NOT supposed to hook that up, its not accurate. That is why most will opt for DSMLINK or like ECU+ anything that can read knock.
You will need to find which wire is the one reading knock and dissconnect it, then get a logger and watch the timing curve through out the run. Goodluck man.
EDIT I see your a 92...I believe your logger can read knock. So thats even better.
