SAFC question
Your settings will be so far to the - that your airflow will be extremely skewed. This can lead to really high timing and poor performance because your ECU will think you are getting much less air than you really are.
Dsmchips.com
Also, PM andymoraitis as he will set you up with the settings when ordering your chip.
I am running 850's with the chip, I threw on an safc just so if I need to fine tune things, I can.. Although, The safc is not needed now.
i_heart_boost said:
ouch. to what cc's is an safc capable?
650cc is where most people see the last place an AFC can be used successfully. Or, like 1993eclipseGS said, get a chip that in effect sets you back to 450's, so any adjustments you make are on the stock airflow numbers. You could run, theoretically, whatever size you wanted, in this case.
