safc problem (fixed) and ghost in my car
d3ftones
Oct 30, 2004
kuala lumpur, Asia
everytime i turn off the car, then when i start/on it back..the safc setting will reset back to factory setting..means it won't work even i have save the settings(initialize).so now i have to enter all the settings everytime i want to use my car.
could anyone here help to diagnose the problem? is it sth wrong wit my safc memory?
is there a probability it is caused by erroneus on wiring eh?
i've use it for 4 months without problems until 2 days ago.3 weeks ago i juz done swapping oversize,forged piston to my car..so not so sure on the wiring.
any specific wire to check?
Quit hitting "initialize".
You do know that hitting "initialize" sets the afc back to its out of the box default setting right?
If you have further problems I'd inspect the wiring. Sounds like the constant 12V source may not be connected correctly.
damn,there's a website i went......well i was misunderstood the info,doesn't it?.ok im gonna try it,and post here again. tnx dude!
safc problem = fixed
now a new problem occured,after setting my safc..i take my car for a run..after 2 hours suddenly my car revving from 1000rpm to 1800 rpm without me using the gas pedal/throttle. the safc also shown throttle=0%. it keeps revving like that.
why is this happened eh?
If you have the patience… solder everything. That’s your best bet. But I had the same problem and fixed it because it was a faulty connection. :)
Joey 99GSX
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
