SAFC o2 input and wideband
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
I just got my safc1 for my 1g and I have the lc1 wideband installed on the car. Can I take the widband output and hook it to the safc? This would give me a good way to log wideband AFR and rpm togeather right? Just a thought.
Did you connect it to the blue wire on the SAFC-II designed for the factory O2 sensor?
Does that input read up to 5 volts?
So can you view the readout under your normal parameters, such as with airflow, tps, voltage?
Just courious, since I don't thing I've ever read of anyone doing this.
Yes it reads up to 5 volts. You can not see it under all the sensors. You can see in under sensor check. So it was a waste of time doing it but it works non-the-less.
