General SAFC NEO problems
black_gst
2,467
29
Jun 16, 2008
IE, California
ok so here goes, i was helping my friend install his NEO and we got everything hooked up and double checked everything to the ecu pinout to make sure its all correct. This is on a 90 gst with denso 660cc injectors by the way, so it idles fine and cruises great but theres this wall at about 5k rpm's/12psi's, it feels like fuel cut... now i know the injectors work great because they were on my car and i was boosting 25psi.
so to try and figure out the problem we swapped in the stock injectors and reconnected the MAS signal and striaght to the ecu and everything works fine.
i have never really messed with SAFC i went stright from the old 5 knob AFC to dsmlink LOL.
so anyone had a similar problem? suggestions?
thanks
brown wire must be close ecu and black like 2 inches from brown . sorry for my english.
set 30 on low and 75 on high
check fuel preasure.
i really dont think 5% on high throttle will do anything. and it didnt matter what throttle point we were at high and low it did the same thing. and as i stated above the car is running fine on the stock injectors with the maf going stright to the ecu now so fuel pressure is fine
