safc monitor
butlar
34
Dec 6, 2004
c.b.s,
When i click monitor on my safc, if i choose airflow is is at 0% and stays there no matter what I do. My question is since i have it on karmen setting it shows HZ and HZ go up and down as I give it more or less throttle. But if i go to monitor airflow it shows nothing and if I try and monitor pressure it stays at like -790 , any help would be appreciated.
The SAFC should be set to monitor karmen. Pressure and airflow is used for different sensors, such as the flapper sensors in Mazdas and Nissan and the MAP sensor used by Honda. Just keep it set to karmen and you'll be fine.
Yes, but what im wondering is when I go to monitor airflow on my actual SAFC it shows 0% and wont change.
