SAFC low throttle settings
idt512
231
9
May 4, 2003
Hemet, California
what is the purpose of setting the low throttle settings when the o2 sensor counters it? it does bog it down when i lean it out but if i let it run for about 20-30 seconds it ends up back to where it was as if it were back to 0. Do i keep leaning it out till its out of the o2 sensors range? :confused:
idt512 said:
what is the purpose of setting the low throttle settings when the o2 sensor counters it? it does bog it down when i lean it out but if i let it run for about 20-30 seconds it ends up back to where it was as if it were back to 0. Do i keep leaning it out till its out of the o2 sensors range? :confused:[/QUOTE
Start reading.--------->Definitive Piggyback Tuning Guide its under Forums and TechArticles. Make sure you have a Datalogger handy.
