Safc II settings.....
awddsm95
96
May 2, 2004
Uniontown, Ohio
hi, im in the middle of my safc II install and am wondering about the initial settings for my set up. You must first realize that im setting my car up for a bigger turbo and fmic, but im installing the safc now on my t25
i have a t25 2.5 exhaust, BR upic w/ 1g bov, msd wires, ngk plugs, ill be running about 17lbs of boost, what should the settings be?
Thanks!
"0"'s across the board for both low and high settings. You don't need to do any fuel tuning yet, so just let the stock ecu handle everything. This is accomplished by setting the safc to 0's, and it will act like it's not even there.
Now would be a great time to get a pocketlogger to learn how to use it, and to see what stock timing curves are like with the t25. You will NEED a pocketlogger once you get bigger injectors and start doing some fuel tuning.
