SAFC II Lo Tuning
jimmybosox
98
Jul 1, 2004
Columbus, Wisconsin
OK -
I am just starting my tune, trying to follow the Difinitive Piggyback Tuning Guide from these forums.
I have a 6 bolt swap in a 1997 Talon TSi AWD Tubo. I have the 255 fuel pump and an AFPR. I have stock injectors (what size are they anyway?) and stock SMIC. I have a 3" turbo back exhaust with high flow cat. I have a big 16G set to 16psi with a MBC. I have a K&N cone style air filter and a hard pipe after the stock MAF to the turbo.
I set the throttle points to 30 and 80.
While I'm sitting at idle the STFT is at about -7 and the LTFT is at about 14. I turn the SAFC down at the 1000 RPM NE point and the only thing that changes is the STFT. Am I supposed to get the STFT down to 0 or do I need to take it down to -14 to compensate for the +14 showing on the LTFT? According to the guide, I need to so the same at a few more NE/RPM points to get the fuel trims right before trying to tune the HIGH throttle settings.
Secondly, my logger is showing timing as 29. I don't know anything about timing, but all I've read says that it should be 5. Am I missing something? Could my logger be incorrect or am I not understanding this? Maybe the logger value and the value from a true timing device are not the same?
Thanks in advance for your help.
Jimmy
Here's my settings and 3rd gear pull from today. Not a very good pull since I let off the gas just under 6000 rpms. Wideband read "rich" for just a splt second at about 4000rpms.
1000 = 0
2000 = 0
2600 = -1
3200 = -3
3800 = -6
4400 = -6
5000 = -7
5600 = -7
6200 = -8
6800 = -8
7400 = -8
8000 = -8
Changed the HI settings just a bit (-4 at 3200 and -8 the rest of the way) and made another pull this eve. I can't view/post the logs since I'm at work right now, but I still have just a split second of "rich" at about 4000 rpm according the the wideband. Is this normal, or should I thin it out another % or two starting at 3800 rpm on up?
Here's my settings for this pull.
1000 = 0
2000 = 0
2600 = -1
3200 = -4
3800 = -8
4400 = -8
5000 = -8
5600 = -8
6200 = -8
6800 = -8
7400 = -8
8000 = -8
