SAFC base map
snailed
53
Nov 10, 2004
ottawa,
I have these mods most of which are new ( big 16g, 560cc, 255lph, frontmount, 3" turbo back, free mods, and safc) and am going to tune it, i know no two cars are the same but i would appriciate it is someone wit roughly the same setup could let me know what their numbers are for a base map to tune off of.
thanks,
Marshall
u said it urself no 2 cars are the same, on a simialr set up a while ago i remember my settings were 1:-24 2:-27 3:-30 4-7:-34 car ran a little rich but pulled hard safely, peak egt's were around 850c on long top end pulls, i changed the set up before adding the wideband, so cant tell u exactly how it all mapped out, but if ## looking for a basemap, that's around where i started. MAKE SURE U HAVE AN EGT GAUGE!!!!!! best of luck
I don't subscribe to the use of an EGT gauge, but whatever gets you a good tune. :thumb:
You do have a logger, right?
Anyway, what you need to do is set your TPS trigger points, decide on what Ne Points you want to use and then set your STFT & LTFT. This will give you a base map for the Hi Throttle settings. Transfer your Lo Throttle settings over to the Hi Throttle table and start your tune from there.
Don't forget to do a leak check and verify that your TPS is reading >90%.
Enjoy!
Yes I do have a datalogger and wideband. thanks for the help and advise quys.
