safc and datalogger?
tom1995tsi
613
Nov 25, 2003
Hazleton, Pennsylvania
I was just wondering if i needed both, because wouldnt the safc show all the same data thanks for the help.
no, safc is a piggyback computer, it just modifies the signal to show more or less air going through. The pocketlogger is what you need to read your timing, o2's, and other data (knock if your a 1g). You need them both if you want to be able to tune. Tuning with just a SAFC is stupid and dangerous. However, if your just trying to get your fuel system together and are still on stock injectors, you can buy the safc, install it, and just leave everything zeroed out.
no you need the data logger to get yout timing and airflow to be able to tune the SAfc....you can use some of the initial setups in this thread liek i did -
http://www.dsmtuners.net/forums/showthread.php?t=15097&highlight=SAFC+setup
you can look through there find your best matched setup and go from there...but i dont reccomend it unles its either on a dyno or you have a logger to se the effects adjustments on teh safc make int eh car
You need both.
S-AFC - To modify the fuel curves and other things.
Datalogger - To view the fuel curves as well as a few other awsome things.
Never try tuning without something to read and something to change. Tuning blind is definately dangerous.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
