safc 2 max injector size?
ya i have an eprom.. i might take you up on that tune for beer deal :) hopefully i have my stuff in a week and have it put in by 2 weeks.
95DsmTsiauto said:
i dont think i can go any more than 20 lbs on stock internals right? O and i always use 93 or 94 octane and im a 95 so i have an eprom.
I know that you said you have an eprom, but this comment makes me think you didn't look at the ECU, not all 95's have an Eprom, trust me i know, mine is one of those bastard ones...
spyderturbo007 said:
Not true. Most 95's came with EPROM ECU's.
well i was told all 95's have eproms..Ill have to check mine out then.thanks for that tip. Would be bad if i dont have one and i order all my stuff .
According to the gentlemen over at DSMLink, not all 95's had EPROM ECU's. They are the ECU kings, so I would trust them.
DSMLink.com said:
How can I tell if I have an EPROM ECU in my car?
Well, first, the only 2G DSMs with EPROM ECUs from the factory are the '95 models. We have seen a few '95 ECUs without EPROMs, but it's very unusual. You can be sure that if you have a '96+ model, you do not have an EPROM from the factory. To check your '95 ECU for an EPROM, go here.
JayRolla said:
All 95's came with eproms, but ecu's have been swapped so many times in our cars you want to check to make sure you have one.
To further clarify, I have a (DSMlink verified) 95 ECU which is non-eprom. In other words, they told me it IS a 95 ECU, but not eprom.
