What Injector Size
force_feed
323
5
Jan 31, 2008
Katy, Texas
I have a quick question for you guys.
I have a 20g, and I want to run about 25 psi. Are 750's big enough or to small?
If they are to small, what injector size do you recommend?
Thanks!
The info's out there, you've just got to SEARCH for it... Injector Supported Airflow
I believe a tdo6 20g flows a maximum of 44lbs/min and if you look at the info in that link you'll see that your injectors will be the perfect size to run for that turbo, they won't be overkill and your IDC's will still be about 80%.
:dsm:
