2G S90 TPS adjustment
Disturbance
152
Oct 26, 2011
Tucson, Arizona
I'm putting my new s90 throttle body on and am just confused about the tps adjustment. I read Steve's post about it but I'm doing Jt with it off the car, is this possible? Also do I probe the actual tps sensor that's bolted on the throttle body or its connector. Thank you for any help
Since your not using a factory TB all bets are off. :)
It looks like you use the factory TPS with it you can start by trying the same adjustments for setting the IPS switching point. It doesn't have to be on the car to do so. You always probe the TPS except when you checking the actual TPS output voltage at the end to be sure it's not messed up. For that the TPS has to be plugged in to the harness.
  • Wanted 6 bolt NT water pipe
    • chrisman287
