RWD 4G63 Subframe mod?
Well by balance I meant safety concern vs getting shit done. I didn't really explain that well, not like f/r balance. Although the stock dsm weight distribution is so terrible I can't imagine you could make it worse. It has allot to do with where you put the weight, you can set the thing pretty far back and low if you are fabricating the whole thing.
I also think the whole dsm drivetrain is heavier than you are giving it credit for, I don't think a big block 1g will be much heavier than stock. I know I'm gonna get chewed for that but if you strip the accessories and all the huge iron/steel crap off these engines they are not that bad really. Minimal accessories and aluminum intake manifold and especially heads and it's on par with an all iron small block.
The bigger comparison for mustangs is that its just easier to use a 351 with the same bellhousing. It's all much more bolt on. If you are talking custom stuff and like with like I don't think it's more expensive to build a powerful big block. Take a look at Scott's website I referenced. There's a spectrum of proven builds using stock ported iron and up for different price ranges.
As far as building a real 10 sec car there's allot more to it than just the engine. If you make a bunch of torque you gotta put it to the ground somehow, everyone likes to argue all the mods you need to get traction with big block torque. How would you not need that with 10 psi on a 5.0? I've done it myself both ways, 500+ ft lbs in a stock fox is gonna blaze the tires regardless of how you make it. A giant electric motor would still need the same supporting mods on the chassis and suspension so that's not really something you can argue.
I already said I thought about this and didn't do it. I agree the 4g rocks. Nothing wrong with using that rwd either. I am only insisting on him continuing with the big block because its what he really wanted to do and I think it will work.
If you really want to dig into it though, at the higher power levels the sheer difference in stress needed to boost a 2.0l engine to the same output vs a 7.5l one is crazy. Not to mention one of the simplest and useful mods for a 460 is stroking the hell out of it. The block is huge and bore/stroke is way over square unlike almost every other big production engine. You can easily bump this engine to 557ci or 9.2l. Right there you need to stress a 2.0l engine, lets say a 2.3 for a fair stroked for stroked comparison, 4x harder. A 351 1.6x more. At levels that are really leaning on these other engines you are not even stressing a 460. So then if you wanted to apply this whole fancy turbo + electronics business on that base, where does that take you? I know you are gonna say a 4g can go well over 1000hp too and you are absolutely right but that is a very high level, expensive , high maintenance engine. Before all the aftermarket cranks/blocks guys in the 60's were using partial block fills on stock blocks and cranks and making 1400+ hp on nitro with these engines. Most of the hp is made in the head/turbo/nitrous system. Making power isn't even so much about the base engine at all, getting the engine to hold it without ripping itself apart when you lean on it is the major qualification for a performance engine in my mind. There's not many stockers that can do this. The 385 series big block, 4g63, 2jz, ls. It's a short list. Once you get past a certain point I honestly think the hp/$ ratio is in favor of a nitrous ls/big block ford.
I wasn't comparing the safety of an old car vs this build, I was just saying look at it from a relative point of view. It's sort of hysterical that this specific community is harping on the safety so much. More of a pot calling the kettle black kind of a thing. The irony of that is just killing me, don't take it personally either way, I just find most stuff funny. I am not defending the structure he has built either mind you. I said specifically what I agree needs to be changed. I'm essentially not disagreeing with any of the constructive criticism that has been given already.
I can empathize with getting fed up with not having your advice taken. It's another one of those funny little life things though, you can only really control yourself, meaning give advice because you want to give advice. It's not really the other persons fault if you are offended if they don't take it, you did what you could do so feel good about that, the rest of his experience in this is on him. Right now I have no idea if anything I am saying is going to change anything, its ok if it doesn't. Its not like my saying nothing at all was going to prevent him from continuing if that is his will. I simply saw allot of energy and enthusiasm and allot of good advice going on here that sort of all took a rather shitty turn, I don't think it needs to be that way so I'm giving it a go.
I won't ever discourage anyone from doing something even if I do think it's crazy. I will explain my point of view but being completely negative with no real content or use is just sort of a waste of life. It's my opinion that experimenting and learning and creating are some of the most essential qualities of being human.
Were just gonna all agree that ## an idiot and just stop reading ## post at the first dumb thing we read. Lucky for us u thinkin that a big block dsm wouldnt weigh much more then stock, came early in ## post.
Something You really need to know that will make you a better troll
somebody had to break it to you, it just happened to be me, and you're welcome!
I don't understand, is that the link you intended? I don't even see where I used the word alot? I will admit I probably do use it and I didn't realize it's not actually a word though.
There's another funny philosophical semantics thing I always enjoyed about grammar.
Word - Definition and More from the Free Merriam-Webster Dictionary
By definition if I say it and you understood it, then it's a word. Philosophy>grammar.
I'm not going to do the research on this atm because I have better stuff to do. If you really feel like proving me wrong find out the average race weight of the rwd conversions on here. I'll give you 640 lbs for the 460 stripped down, 300 lbs for the 4g63. Add 440 to the weight of the average rwd conversion and compare that to a stock awd dsm. Maybe I'm completely wrong, it's just speculation.
According to some ford "muscle" :rolleyes:forums the 460 big block weighs 720lbs, i guess it makes sense stripped down from accessories youd be down to the 640 you say. They also mentioned a 351 Windsor is about 525lbs. Now remember, even they would take the lighter motor setup. I did read your previous post and would like to mention that even if he hard filled that big block and went nitrous etc. and made a magical 1400 hp, i doubt that "chassis" he has could handle the torque on launch, etc. it would crumble. Now i would be willing to bet you though, i could pull off 900hp anyday for less than big iron block 460 dollar for dollar. Also i think we would not even need that much horsepower to smoke a rwd big block dsm, considering a 1g properly built and setup will have less weight with a 4g63 with say about 600hp realstically. This is all speculation and im sleepy :boring:
Albeit everything but safe.... cool he did his own thing . . . I guess.
I'm just worried for the life of anyone around it. Granted we have lost another awd 1g but that's a car, it can be replaced where as a life can not, even his own. If nothing else I'd hope the OP thinks about it for at least half a second before this thing goes on any public road.
Damn it! !!! Had a large post on my phone and hit the back button... anyways.... until you can build a cage you can trust your life, and anyone else around yourself (s) life... you shouldn't do it.
I come from a completely different line of protection and fabrication. But until you can do this.... you should do your homework. ... your shit wouldn't last a day out in what we do.
Notice the bracing here..... and.... what.... there is a firewall to tie it all in!!! Yours is gone... bummer
Dude when are you goin to learn that its not the motor thats what was wrong. Its the Shit fab work that you have done. You need to start over. How about you just do all of us and yourself a favor and delete this thread and dont tell us whats goin on. Because your not getting any respect from anybody here, and we dont care about seeing somebody building something that is 100% unsafe. If you were taking advice it would be different. But all you do is ask for advice and our opinion, but dont listen when we dont say what you want to hear.
:hellyeah:
You kept using ALLOT instead of A LOT...sorry but I can't help being an ass...
I wouldn't go as far as call it philosophical semantics, it's just plain bad spelling...
No, not heated, at least I'm not. Everyone's got their relative perspectives on life, it's this hazy middle part where we gotta figure how to interact with each other coming together from all different angles where it gets interesting. No use in gettin miffed over it.
You are correct that I used the wrong allot a lot, hahaha. I just did I quick page search for alot after you called me on it and didn't see it at first. Just for fun I'm gonna explain my point here.
Allot
The verb to allot means to give out, to apportion, to divide, or to distribute. (Other forms of the verb are allots, allotted, and allotting.)
So you are technically right on that account, I'll give you that.
se·man·tics noun plural but singular or plural in construction \si-ˈman-tiks\
: the study of the meanings of words and phrases in language
: the meanings of words and phrases in a particular context
Like most all imaginary things we use all the time, language falls under a certain category in philosophy. This one is semantics, the meaning of words.
word noun
a sound or combination of sounds that has a meaning and is spoken or written
The definition of a word is simply this, I make a noise or write some marks and you understand what I was communicating. My point is that you did, to explain to me how I was misspelling it means that you understood what I intended and how I did it wrong so by definition we just created a new technical addendum to the definition of alot. Specifically that you can use alot, allot, and a lot interchangeably most of the time with at least a tiny bit of context and most people are going to understand your meaning.
There's a saying I like, "I understood what you meant, not what you said". I'm not necessarily expecting you to adopt my point of view on this but personally I came to the conclusion a long time ago that if I was to try my damndest to let that which does not matter truly slide I would experience life in a much happier reality tunnel. I can expand on the relativistic nature of perception too if you really want me to explain what I mean by reality tunnel but that is really starting to get drastically off topic. I can probably tie that back into the discussion on front subframe fabrication if anyone really wants me to though.
This may seem silly or anal to take this argument to this level but my overall argument has nothing at all to do with allot, it is that having a flexible and understanding approach to language is far more enjoyable than being a grammar nazi. If you really think I am wrong about this I dare you to try and enjoy Ulysses by James Joyce. There will exist an entire realm of artistic expression that you can never enjoy in your life if you continue to approach things in that manner.
Looking good! I am dumfounded by your grit and determination despite the naysayers.
Cage was to stop twisting of the unibody not for weight reduction. I'm sure it only weighs 200 lbs anyways
And you still can't understand how to properly build a safe roll cage.
^^ WTF ???? In an engineering perspective, please enlighten me how this is a safe built cage and the purpose of these bars. 1st: The bars that connect the dash bar to the main hoop have no purpose other than add unnecessary weight, they don't do anything. 2nd: What kind of square tubing you using for the firewall and trans support ? As per NHRA rules, all tubes need to be a certain outer diameter and thickness diameter.. You still oblivious to the fact you keep going at it very wrong...
Just let it go. No matter what any of us say, hes not gonna listen. Were just "haters".
Apparently the NHRA, and SFI rule books are also hating on him.
Along with all the dragsters, funny cars, door slammers, and go karts of the world......
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
