1G Runs Rough When Hot
Stock 1990
Aug 26, 2016
Raleigh, North Carolina
Factory stock 1990 Eagle Talon TSi with AWD (or as close to stock as it can be with 185k miles on it).
Problem started some years ago. Car would run fine but if it had been running at highway speeds then shut off for about 40 minutes, it would run like it was on three cylinders. If the shutoff time was less than that or more than 4 hours, it would run without any problem. Over the years the ECM was changed and other work was done, but the issue remained and only occurred under those conditions, and was less of an issue in cold weather. As a daily driver to and from work or for long highway trips, it was not really a problem, just kind of drove it in a way that the issue didn't occur, but if I forgot or something happened that made me let the car sit for more than 40 minutes and less than 4 hours, and the outside temperature was warm or hot, the issue would occur. Usually, the check engine light did not come on, but I rarely drove it long in that condition. Routine replacement of plugs and wires had no effect.
Over time, it took less and less to induce the problem, but it was always occur more often in the summer months. Fuel injectors were replaced last year due to a dirt problem when the fuel filter was replaced, and that had no effect on the issue. Occasionally I would have to drive the car on the highway after it sat more than 40 minutes after previously having been run, and if it was driven at highway speeds for about 15 minutes the problem would go away and the engine light would go off. This convinced me that some thing was being affected by the heat and the normal operating temperature of the car was not the issue. (The car has always run at normal temperatures and has never run hot.)
This summer the problem started to occur when driving it on the highway for a couple hours, then getting into stop and go traffic at long traffic lights, etc. Finally, about mid-summer it started to occur after about 20 minutes of driving in any condition. When the car ran like this for some time (usually more than 10 to 20 minutes, the check engine light would come on. Being an ODB 1 car, the local parts places couldn't do a reading for me.
After living with this the better part of the summer, I examined the plugs after a two hour trip at highway speeds with the car running roughly with low power and found cylinder #1's plug was tan, wet and glossy looking while the other three plugs looked normal. That, combined with other people's experience made me think the "running on three cylinders" description was more accurate than I had even suspected. With the car being 26 years old, the ignition coil or Ignition Control Module seemed to be the culprit, thinking that a micro fracture may have occurred that expanded when heated up.
Replaced the plugs, wires, ignition coil unit and the ICM with no useful effect: the problem still occurred after about 15 minutes of driving in the 100 degree heat today and the engine light came on. But the problem went away (and the light went out) after another 5 minutes then the problem came back. This repeated with another 5 minutes of driving. The car was parked for about 20 minutes, and the problem came back as soon as the car was started. Returning home, a bulb from a 6 volt flashlight was connected between pins 1 and 12 on the diagnostic connector to see what the code might be (since the engine light had stayed on), but the flashlight bulb did not light up even once.
What do I look at next?
The check engine light coming on like that, but not storing a fault code, could be indicating that the car is overheating.
Have you checked your coolant level and the condition of your coolant lately?
I don't like using an incandescent light bulb on the diagnostic output, they can draw more current than the ECU driver supports and burn it out. I only use LEDs configured for 12v, Low current 12v Piezo buzzers, analog multimeter, or datalogger to read the codes.
Has the ECU been replaced, or the capacitors replaced?
Did you ground the diagnostic pin (10) on the DLC when you were looking for the fault codes? (That would put it into datalogger mode)
Do you see a heartbeat from the DLC data pin (1) when the the diag pin isn't grounded? You should get either the heartbeat or a fault code. Neither indicates a problem with how your looking or a bad ECU. (not a cooling issue IMHO)
I'm assuming you don't have DSMLink since you say it's stock. DSMLink would add cases where you get a CEL while running but there isn't a stored fault code, for things like knock and coolant temp.
Ignition related issues usually are paired cylinder wise like 1 and 4 or 2 and 3 due to the way a wasted spark ignition works. When you have problems with a single cylinder it tends to be fuel or ECU related and your changing the plugs, wires, coils and power transistor to no improvement isn't surprising and would support the trend.
How old is the fuel pump? Do you have an in car fuel pressure gauge to monitor consistency? I experienced similar symptoms, after replacing the pump it improved.
Dhan - The coolant was changed out less than two years ago, but it was about a quart low when I checked. Thanks for the reminder. I've filled it up, but no change to the issue resulted.
Steve - The whole ECU was replaced less than ten years ago. I'm going to go find/configure a LED this week, get a buzzer, or borrow an analog meter (I only have a digital VOM). I had not grounded pin ten; I didn't see anything about that in the manual.
No DSM Link is in this car.
PlanZero - I haven't checked compression, but with 185 k on the clock I expect it will be a bit low. Plus, the car does consume some oil, though no leaks. (Not enough oil burning to foul the plugs at all, anyway.) Worth getting checked, as I will probably need to get the engine rebuilt before it hits 200k. Want to solve this issue before that, however.
ohnoz - The fuel pump is original, located in the tank. There is no in-car fuel pressure gauge. No issue was noted with the fuel pressure when the injectors and fuel filter were changed out last year due to being clogged, and the problem was occurring before and after that was done. (The fuel rail was also replaced when the mechanic accidentally cracked it, so he had done a pressure check when putting everything back together.) However, I hadn't previously thought the fuel pump could cause these symptoms, so that's something to consider.
If the check engine light comes on when this occurs you should have a code . i have a customer that comes to the dealership that has a 91 eclipse none turbo that had a problem like yours that after he drove it for awhile the engine would run rough but when i scanned it there were no codes so i had to drive it until i experienced the problem and the check engine light was on . when i scanned it this time there was a code for injector 2 circuit . checked the resistance of the injector and it was off . you said that you already changed the injectors so that eliminates that possibility . If you can find a dodge dealer that still has the tools to scan your car when the problem is there it could point you in the right direction . they shouldn't charge you a lot for just scanning your car .
I asked about grounding the mode pin to eliminate variables. Doing so would have caused the ECU to be in datalogging mode rather than heartbeat/fault code mode. Same for asking about DSMLink, eliminate more variables.
10 years since you last checked the ECU is a really long time.
There are other far more unusual things that could be going on that could cause cylinder 1 to drop out. Checking compression when cold and again once it starts acting up might rule out or open up some paths of diagnosis.
