Running rich, AEM fuel rail and stock FPR
justin_t_2
Apr 13, 2010
Roseville, California
I live in California so you guys know all the smog rules. Okay so my car has been running rich lately and my AFPR was apparently dead. The reason why I thought it was dead is because I would drive adjusting the FP and it would do nothing. So I went out and bought the stock FPR and swapped it out with the AFPR. I have a FP gauge on the rail and it was reading 40 psi with the vac hose connected and 45 psi with the vac hose disconnected. Anyone have any suggestions on what I can do about my car running rich?
is your bov recirculated?
What makes you think you're running rich? I don't see a Wideband on your mod list.
Blinky- His BOV being vented is only going to make a difference in between shifts. I won't affect his A/F ratio any other time.
I have the stock bypass valve and running stock injectors. And the reason why I said it's running rich is because I can smell all the unburnt fuel coming out the exhaust and every time I let off the throttle and shift, there is a puff of smoke coming out the exhaust.
No my bypass valve isn't vented. It's recirculated. Yeah I'm thinking that it might be a bad O2 sensor
Like Aproductions said, what injectors and engine management are you running and you certain need a wideband. And you certain need to check on the TECH: Upgrade Paths. A) don't need an AEM fuel rail because the stock is at least good for 500HP, B) if you running a stock turbo etc... and have a 3" exhaust setup its most likely going to cause boost spikes, C) Pacesetter manifold is most likely not going to do you any good, etc...
