Running lean stumbles on accel
ryankreps
Jan 12, 2007
dallas, Texas
Symtoms: Running lean. Stumbles if i accel past 50 percent. Stumbles at idle. Sometimes backfires very lightly. Light smell of gas in the cabin.
Replaced: Fuel filter, spark plugs, coil pack, spark wires, CAT, EGR silinoid, vaccum lines, Every sensor except coolant temp sensor, cleaned throttle body, Tested fuel injectors(stuck a stethiscope against) , and a compression check, 180s accross the board.
So when i bought the car it had been sitting in a garage for 2 years.
I have owned the car for almost two years, and has had the problom for that long.
When i first got the car it would do what i described then i would keep holding the gas and it would kick into gear and accell as if i had a turbo. Doesnt do that anymore.
sometimes if i let the car sit for a few days it will run great for a couple hours or so.
About once a month the cel will flash for a few seconds and the go away immediatly.
This problom is very annoying, i have searched the forums and found nothing involving this problom.
If someone could please help me resolve the issue i would be much appriciated.
This is a 95 2g nt
This is a 95 2g nt
my car was stumbling after i gave it more than half throttle i thought it was a bad ecu since mine was indeed bad long story short i swaped the motor into another car with new wiring and ecu and im waiting on my trans to find out if that fixed it keep me updated
