[RESOLVED] engine stumbles on acceleration
92blutalon
186
Dec 7, 2008
bridgeview, Illinois
my engine stumbles when i start to accelerate. and then the check engine light comes one then once i let off the gas pedal it turns off then it is ok but it dose it in all gears
You might need to check the plug gap, or get new plugs. Your ecu might be detecting a missfire.
.30-.32 on a n/t. will be fine.
Thats all i can think of because of your check engine light coming on when it acts up.
Let me know how it goes!
You might check your tps there are threads on here that tell you how I checked mine and it was bad mine was doing the same thing
my 93 NT says to gap the plugs @.039-.044". There is a sticker on the underside of the hood that tells you the plug gap and timing.
You can retrieve the error code from the computer even if the CEL isn't on. I think that is smart way to go about it. No need to guess. The car is trying to tell you what's wrong. Get a hayne's or chilton's manual, and an analog volt meter or an LED. Or borrow someone's datalogger.
He needs to edit the post because he fixed the problem.
