Running lean I think
Evo caro
Dec 30, 2016
Fort hood, Texas
Need some advice my evo 8 started Having a rough idle when coming to a stop were it wants to die out I suspect it's running lean the mods I have is greddy boost control and uncatted full exhaust and I had a cel p0090 but goes and comes
Hi!
I don't mean to be rude but there are evo forums which probably will be able to help you better than a dsm forum Yes we do share lots of parts between the 2 platforms but the evo community is as big as the dsm! Now If this was a DSM with the same issue a would tell you to check the ISC/IAC and check for boost leaks also a highly suggest you to get a wideband!
the p0090 code is for Fuel Pressure solenoid. The solenoid should have a vacuum hose that goes from the intake manifold to the fuel pressure regulator on the fuel rail!
I think your CEL and rough idle are unrelated. The CEL is not "uncommon" in the Evo community and there are a few threads you can review on Evo M. For your rough idle, I would start by pressure testing your intake (blt/boost leak test).
Additionally, I would HIGHLY suggest you pick up a wideband setup to monitor your actual AFR's and a way to datalog such as the Tactrix cable and Evoscan.
How do you do a boost leak test
do you
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
