Resolved 1G - Running lean
Gooeytaro
35
11
Aug 26, 2022
Silverdale, Washington
Currently running lean. Person I bought it from says it just needs tuned. Is there anything else I should look at to see if there is a different issue? I need it to stop so it doesn't stall on stop and at low speeds/rpm
Solution
My lean running issue has been completely solved as of 09-01-22. Tune solved all of my problems. Will update further if issue proceeds but consider this post closed!
How do you know its lean? Stalling isn't necessarily an indication of lean.
Mod list in your profile would be nice. See your running ECMlink v3. But we need more info. Running lean at idle? Cruise? On WoT pulls?
I wish I knew the full list. I bought it project off of a dude only yesterday.
More info: it runs stupidly lean at idle, when boost is active it is at a good clean 12-14. Any time I put the car into neutral or stop or drop rpm fast it INSTANTLY goes past 18. So high it won't even read it
I added what all I know in my mods list if anything of that helps.
12-14 is NOT good under boost, that’s lean under boost even for e85, definitely don’t get into boost until you can see what’s going on or get it tuned.
