Running a bit lean at idle, idle surging, lc-1 intermittently reading 7.4
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
My car recently started running a little bit lean at idle (A/F Ratio 15.0-16.0) where before it used to sit nicely at stoich hovering between 14.7-14.9. I am also now getting idle surge suddenly. Before this all happened, my Innovate LC-1 Wideband gauge was flashing 7.4 for a few hours. It runs just fine for about 30 seconds in open loop until the sensor warms up.
The Wideband is setup to simulate a narrow band. The wideband is mounted in the stock O2 location and only has about 9k miles on it.
Is this a dying O2 sensor or LC-1 module possibly? I can run a BLT test but wanted some ideas before I did so. Last BLT test was run only 3k miles ago and I fixed all leaks at that time.
I am going to tackle the fuel filter first because it needs to be changed and wanted to rule that out as a cause of running lean since I have one handy but that wouldn't be causing the idle surge.
Thoughts?
Thanks
Good links, have read them in the past and will go down that route for sure. I am a little bit suspicious of the O2 sensor reading 7.4 though. It hasn't read that way since the problem started but still. I guess it is cheaper to proceed with those methods again along with a BLT since it isn't my daily.
Vacuum leak yessssssssssss!
Turned out to be a 3 way tee that I used in place of a normal vacuum connection. Used JB quick to plug it. Guess it got sucked in LOL!
