tylerb826
- 2
- Aug 28, 2009
Eatonton,
Georgia
I jus recently bought a 92 Eagle Talon Tsi with Evo16g turbo, exhaust mani upgrade and all sorts of other turbo goods that you can read bout on my profile. But it has its problems the wide band is showin that is runnin lean all the time. The PO never hooked up the new o2 sensor and i cant find the wiring to plug it up.
would that cause my lean condition? If so if i hooked it back up if i found it by a miracle how would i tune the car so i can daily drive it. I got the boost turned down to basic stock boost no more that 10 pounds. I need help on gettin this thing tuned so ill feel safe drivin it
Its torn down right now. Im fixing a oil leak on the turbo. Previous owner broke the oil return line bolt off in the turbo so it has a leak from hell.
Anything to get my on the right path will help alot. Im new to turbos.
Thanks
Thanks
Anyone know exactly how rich this makes it? AFR-wise? Does it change under WOT?
