Run 14b on 2g bcs or wg to jpipe?
always_broken
468
Nov 14, 2006
werx, Utah
Was wondering if I install the vacuum lines on the 2g bcs what psi I'll be getting? I've read some people run a vacuum hose from the compressor housing to the wastegate. Which should I do?
Oh, and does it matter which vacuum line goes where on the bcs? Like the wastegate hose goes to the bottom or the top?
On my 14b I have the BCS hooked up. I removed the solenoid in the BCS and it holds a steady 14-15psi. If I hook up the WG straight to the jpipe then I get around 9psi.
So you have the bcs hooked up, but removed the solenoid?
I'm not following you, it's not the screw you're talking about is it? LMK, i'm kinda confused.
  • Wanted 6 bolt NT water pipe
    • chrisman287
