Hey guys, this article is to show you how to install a Road Race Engineering Downpipe w/ test pipe onto an already installed Apexi N1 Catback system with many pictures. First off, this is not a complicated process if you take your time, I am just trying to tell you guys the step by step instructions on how to install this downpipe as well as some problems that you may encounter. So here we go:
Here is the downpipe and the package it came in:
Here is the downpipe, test pipe, gaskets, bolts and nuts all laid out:
Close up of the downpipe:
Hardware:
Measurements
Testpipe/End of Downpipe (hard to tell in the picture but it is a true 3"):
O2 housing connection:
1.) First up, jack up the car and safely support it with jack stands. I suggest before you do anything, spray PB Blaster on the bolts that connects the downpipe to the O2 housing and also the bolts that connect the stock downpipe to the Apexi N1 cat-back system:
HINT: What I did was spray the places (meaning spray them like no tomorrow) and let it sit for about 1 hour. Then, after 1 hour is up, spray the places again and let it sit for 2 hours. Then, right before you go and start breaking the bolts loose, spray it again one more time. With this method, I did not even need a breaker bar and the bolts came off VERY easy.
Here is the stuff you need:
Here (circuled in red) are the places you want to spray with PB Blaster and when finished spraying, un-bolt the nuts that secure the downpipe. Also don't forget to pry off the rubber hangers that secure the cat:
There is another bolt on the other side that you can't see that you should spray and then unbolt:
Also, you need to dis-connect the grounding strap from the cat heat shield. On mine (you can see in the pic) was rusted on there pretty bad. So, I ended just cutting around it (or just ripping it off, in my case since it was so rusted on there pretty good, it just fell apart) More on this later...:
Hardware:
Measurements
