Rpf1 size help!!!
You won't fit them unless you stretch tires. My 17x8 +35s with 255 wide tires were damn close on both sides.
I'm currently running some RPF1's on my 2g talon, I dont know the offset off hand, but there 235/45/17s
They rub the plastics in the front pretty bad, the rears have a little slit in them from rubbing the upper wheel well, its not terrible.
Ok so then what do u guys think would look better 17x8 or 17x9 ? And the rims on the above pics are tight but I want them with a bit bigger lip and the middle of the rim to be more inside than the lip...
