rough idle with stroker engine
maddog_187
89
Mar 11, 2006
Grand Junction, Colorado
Any help will be greatly appreciated. I have been working on this car for 3 years now I have learned a lot but lets face it there is a lot to learn when it comes to dsm's. I have had nothing but problems and still trying to work them out. I have a 90 with 2.3 stroker kit, 880cc injectors, t3/t4 hybrid, stage 3 dsm chip and a Maf-t. I need a new transmission so I've been working on the engine because it runs rough. My idle is around 500 and lopes I've tried adjusting the biss screw with no luck using both chilton and hanes manuals. I recently swapped out the biss screw because some idiot before glued it in. :banghead: I have a few questions I was hoping anyone could help with.
1. what should I set ignition timing to with the stroker kit?
2. If I have a dsm chip set for the 880 Injectors what should I set the maf-t to?
3. What other noobie mistakes could I have made? I'm sure a lot :ohdamn:
Thanks for all the help I have tried lots of researching but just not sure where else to look.
So what do you guys think the chances of the valves being bent? Should I just change cam gears and time it or pull the head first?
That's what I was thinking too. I would hate to buy a new gasket if things are fine the one that is on there is a brand new one already.
I agree. If it runs fine other then a rough idle valves are most likely good. You could do a leak down test to verify.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
