1G Rough idle and stall after engine is warm
94gsxawd
Dec 25, 2009
Boise, Idaho
I am trying to diagnose what is going on with my 94 eclipse gsx. It cold starts and idles perfect but after the engine is warm Im having an odd problem. It will start at low rpms but idle very low and rough and stall if I dont stay on the gas. I tried a new IAC valve and cleaned the old one and neither have helped. Any help is greatly appreciated! Thanks
if the resistance tested good on all the coils it could be a problem with the plunger being frozen, I had a few all tested good but only one turned out to actually work, also check for vacuum leaks, maybe do a BLT (boost leak test) always good to do if it's a "new to you car"
any check engine lights, does it always do this when its warm? or every now and again? Previous owner may have messed with the biss screw improperly just throwing out ideas on where I would start
It has been an intermittent problem. Today was the first time its done it in awhile but there is no CEL on. Im starting to suspect a vacuum leak. I had it in the shop a month ago and its ran great till recently.
I took a look at my tps and found a tiny spot with bare wire showing. I wonder if thats whats been causing this. Thanks for the info
If that doesn't work check your Tstat. If it's bad it won't open and keep your car thinking its in and out of cold start
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
