Rod / Stroke Ratio Question
95 TsiAWD said:
thanks for the info...
i forgot to ask if anyone knew the ratio for the 4g64
The 2.4L is the same as the 2.3L unless you go with the long rod option.
whats the exact displacement of the "2.3" and "2.4" motors?
isn't it something like 2.387 for the "2.3" and 2.391 for the "2.4" (totaly guessing, but basicaly they are both very close to 2.4L, the only reason for the differing names is to tell which is using the 4g64 block, at least thats what I ASSume)
Depends on the bore size. My 2.4 is actually a 2.43L because the bore is huge. :D
jeff
