95 TsiAWD's Talon TSi AWD
Eagle Talon TSi AWD
JM Fabrications DRAG Intake Manifold w/ nitrous ports, Accufab 75mm Throttle Body, Tial Q BOV, Spearco 2-216 FMIC (3" coldside/ 2.5" hotside), GT40R Turbocharger (Jet-Hot coated turbiine housing), Shearer Fab TopMount T4 Exhaust Manifold (Jet-Hot Coated), TWO Tial 44mm Wastegate, JayRacing alternator relocation kit, BJ's Fuel Rail, PTE 1600cc Injectors, Fluidyne Aluminum Radiator w/ -16AN steel-braided upper hose, FAL Fans, Flex-A-Lite Power Steering/Oil Cooler, Custom 3" SS V-Band Mandrel Downpipe, APEX'i GT-Spec Catback Exhaust.
Mods-EMS & Logging
Autoronic PnP Standalone ECU, Autronic 500R Ignition amplifier, Hayabusa Coils, Innovate Gauge Type Wideband, AUTOMETER Voltage, Fuel Level, Oil Pressure, Boost and Water Temp Gauges.
Mods-Drivetrain
PTT Twin Disc Clutch Kit with cintered discs, Custom TRE Stage3 Trans, SpeedDesign 4spider diff w/ Torrington Bearing upgrade), THREEspeed Scattershield, solid shifter bushing kits (shifter plate & underhood trans), Wilwood 12.2" 4-piston calipers (front), RRE Slotted Rear Rotors (vented rear), Hawk HPS Pads.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
0.0 lb/ft
Dyno Type
Dyno Dynamics
Dyno Shop Name
ATX Motorsports, NJ
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Full Garrett
Boost : 22
95 TsiAWD
More in 2G DSM
Share this Vehicle
