Rod and Cam advice
phil11
Sep 15, 2011
New Albany, Indiana
Rod strength and cam advice
I'm trying to decide between manley I beam, manley h beam, or eagle h beam. Im shooting for around the 700 whp range... Any opinions on these three?
Anyone running 280 cams? Have any problems with the car dying at stop lights etc. ?
At that power level, I'd stray away from standard h-beams. I'd go with a manley turbo-tuff I beam connecting rod, it should easily take that power. Remember though, its not always about parts, a good tune can go a long way. A bad tune can wreck the strongest of internals.
Yeah thats what i hear, but do you think eagle h beam can handle it with a good tune?
So ?
Yeah i've decided on 272 cams... any more opinions on the rods?
ok you have decided on 272 cams, but whos grind? Have you looked into what add'l parts will be needed with the cams?
personally, I perfer H beam rods.
Yeah crower or jun. How did your h beams hold up? I don't want to spend all this money to find out my block isn't strong enough. And yeah I'm gettin valves springs and retainers too.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
