revving high after boosting????
weapon0x2
71
Feb 8, 2010
arlington, Texas
Last night on the way home from work I boosted. And got up to about 4k rpms and then I had to slow down rapidly, but I noticed my rpms were going down rather slowly. so once I parked the car I noticed instead of idling like normal it was idling around 2k rpms in drive and over 3k in neutral and park. Even when I turned the car off and let it sit for a couple seconds and then turned it back on it was still doing the same thing.
I don't know what's wrong I recently did a t25 to 14b swap and I am using the stock 2g Bov.
You profile is not complete. What are you tuning with, if anything at all? ECMlink maybe?
From my experience if the throttle body is sticking from being dirty and gummed up, you would have other issues like vacuum problems and etc. All that stuff that gummed up your TB would be in everything else, (vacuum lines, FPR BOV.) I don't think it is the TB, although I could be wrong.
-Check you idles switch that it is working properly and out ISC motor.
If you have ecmlink, you can adjust TPS and simulate the idle switch. If its you ISC, you are going to need to have that replaced.
Can anyone answer this, are the ISC motor the same for 1g and 2g?
-Goodluck
I'm am not tuning with anything I only run 11 pounds of boost so it should be safe...its turns out the TB was stuck
